edge or bully dog
It looks like if I want the outlook bully dog hands down is the way to go. but if i put gauges in smarty is the way to go. can a smart be stacked with a bully dog or will bully dog do everything the smarty will do?
smarty won't stack with the bullydog.the smarty can do alot more tuning than the bully dog. If you plan to stack...lets just say a turbo, cp3, injectors, tranny will be needed first. smarty has three different flashes. revo, revo tnt, revo tnt race 4000 rpm.
I had the Smarty in my 04.5 H.O. Cummins, with triple gauges those are a must. The truck ran awesome with quicker response and lower egt's (compared to the Edge EZ, Edge Juice/Attitude, Superchips Cortex and Predetor that I ran on that truck). I did run the Smarty stacked with the Edge for a short while, I will tell you what a ride.
I elected to go with the Tripledog downloader w/outlook monitor (triple gauges also going to be installed) on my 07 Cummins IMO works a little better on my 07 5.9 Cummins. DDP 62/14 non-waste-gated turbo, DDP 90hp injectors and FASS 150g/h fuel system going to be installed as well so we'll see how it responds.:D
The Bullydog Power Pup or Triple Dog can be used with triple gauges and without the outlook monitor for more accurate readings. The Bullydog runs lower egt's, higher power levels and better fuel mileage.
Again, Bullydog over Egde Juice.
The Smarty will stack with chips that plug in under the hood only!
Can't stack programmers over each other.
