well hopefully you guys can help me once again. i have about 250 miles on my top end rebuild. i was riding saturday afternoon. i hit a bump it jarred me pretty good. as i started up the next hill i gave her some throttle and she blah blah blub i backed out and it sounded fine so i gave her some more blah blah blub bang! back fire. i pulled over and it was idleing perfect! so i shut it off and fire it back up. once again idles great. well the road is a mile ahead so i decide ill drive it to the road. i had to give it full throttle and rarely reached 20-30 mph. well i parked it at the road and picked it up with the truck and trailer. i change out the spark plugs sunday morning and it fires right up first pull. never took it off the trailer cause i was heading back home. i get home and try to fire it up and wham just about pull my arm out of my socket. the pull start recoiled back so hard it was like trying to pull start a 12 cylinder CAT motor. i try it again with very similar results. i pull the plugs and it pulls like butter. check compression. 125 psi on both cylinders give or take a few psi (cheap gauge) replace my plugs and its pulling over very very rough seems like its a clogged exhaust port/valve so i pull my VES setup and it pulls smooth again. i take the cover off one of my bellows and it looks in rough shape. so i called the dealer today and ordered two bellows. also i pulled my air box and drained my carbs, there was water in my bowls so i pulled my carbs and there is some dirt down in the bowls. ordered new gaskets to put them back together. what am i missing? anything else i should check?
