EBC loosing boost over 069
My ebc works great up to 069 numbers entered into box running 9 lbs boost. If I enter enything over 070 the boost goes to 6 lbs which is the same if i set a 0 any ideas?
try raising your base hp setting. first screen on ebc 0+0=0,try 0+10=10. fromwhat i understand that will raise your base boost then add your alt comp to get to your boost at alt.
Boost leak some where? It may hold 9# than anything more causes it to 'open' and leak.
Also give your rod to wastegate one full revolution tighter and see what that does for your boost.
