How often do you Duramax owners change your fuel filters????
Fuel filter is reccomended to be changed every 15,000 milesHow often do you Duramax owners change your fuel filters????
If the truck is hopped up with a chip and intake I would only go 5000 miles max on an oil change but the fuel filter will not change, still at 15,000 miles.Does it make a difference if the truck is stock or not??
If you do a lot of towing or off roading you should not go over 5000 miles, if you are just mall crawlin you can get 7500 miles Max.OK im brand new to this diesel truck stuff, so how often do you recommend changing the oil
When it says "Oil Life - 0%" I change the oil.
When it says "Fuel FIlter Life - 0%" I change the filter.
