C
cokingcat
I had my sled parked with the break on. Some stranger lost control of his sled and hit mine (05 King Cat). He bent the stationary sleeve on the driven clutch. I replace both sleeves, used the same spring (and setting), helix, and washers (for the gap). Everything is stock on the clutch.
Now for some reason I have more low end power then before, but now and only when I am off the trail in the powered with full power the belt slips out at a really high rpm?
I am going to take it off again Friday night and check the following per the service manual-
I am going to make sure that the dots/mfg are lined up, I am not going to tighen the helix screws up until the end like it says, and be sure the key matchs to the drive cluch
What else can I check, do, change or test?
Any thoughts are welcome.
