My cap says xps....
Even the earlier non-vented version has XPS on the top. Nearly bought a few of them off E-bay, it would have been bad! Best to turn it over and verify the green duck bill and pinch the wide part and make sure it opens. FWIW
My cap says xps....
sounds like squirrels fighting over a bag of corn.
I sat the oil tank upright and it dripped to a stop,
I think you found your issue...
Why does it look rusty? What's with the scalops around the tops of the pistons?
You still don't get it do you?
Gravity is not the feed mechanism......
I don't know what rust you are seeing
The marks on the piston are from the piston meeting the top of the dome, the rktek domes have patterns cut into them, when the bearing seized it flattened rollers and gained about 1/4 inch of slop, s
Allowing the piston to meet the top of the dome in direct contact
I've seen a few rod bearing failures.
A lack of oil will take out the top end far before the bearing. A lean/ sqeek.
Usually a history of detonation even minor hastens rod bearing failure.
(A common rktek trait)
Summer storage is critical.
even when running 130-140:1 fuel/oil in the tank, a top end is likely to go before the bottom end?
any other evidence of RKtek det issues?
im still leaning towards poor summer storage on my part, although when doing my top end my top roller bearings looked in perfect shape to my surprise.
so I did not expect my lower conrod bearings to look any different at the time.
