C
catmanm7
ttt
On these boxes, to make sure they are hooked up correctly, is the box going to run through the modes while the sled is on a stand.
For example:
I just hooked up the pure logic box on the m7 turbo. The box will cycle through the green at startup and then occassionaly flash green on left side and red on the right at an idle (no injector signal?).
Now my sled idles fine, and is running on both cylinders. When I rev it up the box does not do anything. Shouldnt the box flash a green light when reving and then go into the yellow, red etc?
I have boost turned all the way down since I am in my shop at low elevation. Boost will go up to 5 or so and yet the box still doesnt do anything. I am not WFO in the shop because on elevation and I dont know that the box is working correctly. I will rev up to 5-6000 rpms. Does the sled need a load on it for everything to work right? Do I have to put it in the snow to make sure it is working.
Settings: Grn 1, Yllw 1,Red 1, Grn blue 3, Yllw blue 2-3, Red blue 6
Thanks for any help
For example:
Thanks for any help
