You can get by without a tool if your very careful.
The locktight they use is VERY heat resistant. I got the nut off the first one but it took enough heat to get the bellows smoking. Then the stud (2 different size threads, that I couldn't match up with anything in my nut drawer, with a "hat" as they call it in between) needs to come out to remove the valve from the body.
I wrapped the "hat" with a hose clamp and applied mucho heat and finally got it free turning it with some channels lock pliers. I believe the tool clamps this "hat" in a vise and you turn the valve.
On the second one (and the reason I say you need to be very careful lol) I applied lots of heat and it still wouldn't loosen. So I got it to the point I thought the bellows were going to melt and gave it a bit more push and snap lol. Dang. I used the hose clamp method to get the rest of the stud out of the valve.
No one around here knew of the design so no parts around and ordered it but I didn't want to be out of a ride. So I chucked up the nut and drilled through the broken stud and easy-outed it with way too much heat for the bellows. Then chucked up the rest of the stud and trued the broken edge, drilled and tapped for 6mm and reinstalled with a short head allen screw of the proper length through the original nut.
Still there and just fine with the new part in the drawer for next time lol.
I don't know why Poo thought this needs to be so "secure". My old Doo's were just fine with a plastic nut. You need to take this nut off before you even need the special tool.
I posted my experience cause if it saves one person from this grief on a Fri. night it will have been worth it. If I had done it once before, I would suggest just decoke the valve carefully, wash it well in solvent then quickly in hot soapy water and blow dry without taking it apart.
