At what RPM is the SLP setup getting the hp bump?
I know they couldn't spec it for the 14/15 catalog, and have never seen it. I would guess at least +200 to 400 RPM. I've run SLP pipe/can combos before - they bump the max hp RPM to get the results, which is why they almost always need more fuel. And it works at WFO. They proved it with their pro setups.
FWIW, their pipes are designed for their cans - I've seen peeps try to run cans designed for the stock pipe with the SLP singles - but not for very long at WFO. The rule has been - you can run a SLP can on a stock pipe, but you shouldn't try to run a stock-pipe designed can on a SLP pipe - way too tight, regardless of fuel.
