Do I just have bad luck? Damn A-arm bolts...
J
John
ACCOUNT CLOSED
/RANT/ Had to do bottom A-arm on the KK and had to cut off the bolt. Got the part today and it won't go together because the top one is bent too. Go to take it off and that one is rusted to the damn tube as well. Why dont they put some grease on there before putting the bolt through. :confused: Morons. \RANT\
funny to read this, i just went through the same crap with mine!i ended up using an air chisel and drove the bolts out, destroyed the washer but got them out, no wd-40 in the world would help get the %&^$*$* things loose.i geased mine and drilled the a arms for grease nipples and drilled little holes in the tubes for the grease to get in, all hoping to help them cheap plastic bushings last alittle longer.
