?? do I have this info straight on chevrolet?
I was thinking the other day about this and wanted to see if I'm thinking right
Chev accepted 2 bailouts,
they went bankrupt and washed away all their debt.
they are now going to get approximately 1/4 of the new $4500 car sales......
Taxpayers pay for the bailouts (x2)
taxpayers pay for going bankrupt
we are paying the $4500
So I'm giving chevy $ for 4 things and not receiving anything.....
is this true?
spomey
Chevy or any of the manufactures will not be the direct beneficiary of the cash for clunkers money, the consumers that are eligible and are able to qualify for the program will be. Manufacturers will indirectly benefit from an artificial increase in sales, but they don't get to keep $4500 on top of what they make on a car sale.
That doesn't counter the fact that taxpayers are still paying for it though, regardless who benefits - (lets not forget the environment, it will be SO much better off without all those old gas guzzling CO2 belching clunkers.:rolleyes:)
So what happens to all the gas-guzzling clunkers that are turned in for shiny new cars?
IMo they should be recycled as part of this program....but I'm guessing they will be sold and continue to pollute, defeating the purpose of the "plan".
Just like the greenies that brag about saving the environment by driving their Prius.....yet they traded in their old guzzler instead of destroying it. Makes no sense :rolleyes:
the engines are required to be drained of oil and filled with sodium silicate and
run until the engine seizes. Look up sodium silicate and it will tell you that when exposed to heat it turns to a glass like substance the has a melting point of 1500 degrees, there by rendering the offending engine useless.
Can't recycle a glass engine
copy and pasted from the last doc from cars release:
Engine Disablement Procedures for the CARS Program
THIS PROCEDURE IS NOT TO BE USED BY THE VEHICLE OWNER
Perform the following procedure to disable the vehicle engine.
Since the vehicle will not be drivable after this procedure is performed,
consider where the procedure will be performed and how the vehicle
will be moved after the procedure is complete.
1. Obtain solution of 40% sodium silicate/60% water. (The Sodium Silicate
(SiO2/Na2O) used in the solution must have a weight ratio of 3.0 or greater.)
2. Drain engine oil for environmentally appropriate disposal.
3. Install the oil drain plug.
4. Pour enough solution in the engine through the oil fill for the oil pump to
circulate the solution throughout the engine. Start by adding 2 quarts of the
solution, which should be sufficient in most cases.
CAUTION: Wear goggles and gloves. Appropriate protective clothing
should be worn to prevent silicate solution from coming into contact with the
skin.
5. Replace the oil fill cap.
6. Start the engine.
7. Run engine at approximately 2000 rpm (for safety reasons do not operate at
high rpm) until the engine stops. (Typically the engine will operate for 3 to 7
minutes. As the solution starts to affect engine operation, the operator will
have to apply more throttle to keep the engine at 2000 rpm.)
8. Allow the engine to cool for at least 1 hour.
9. With the battery at full charge or with auxiliary power to provide the power of
a fully charged battery, attempt to start the engine.
10. If the engine will not operate at idle, the procedure is complete.
11. If the engine will operate at idle, repeat steps 6 through 10 until the engine
will no longer idle.
12. Attach a label to the engine that legibly states the following:
This engine is from a vehicle that is part of the Car Allowance Rebate
System (CARS). It has significant internal damage caused by operating
the engine with a sodium silicate solution (liquid glass) instead of oil.
Oil
no not a Dem full on conservative here, just still have problems with the whole blindness of actions and that people actually believe some of it. Think about it, the shear stupidity of these actions then, more than 1/2 of the population of this country are gung-ho democratic loving it. the thing is I only know 3 people who voted for the dem....
Sounds like putting better windows in your house or something they say oh it will save on your heating bill by using less gas,better for environment.But the old windows were doing their job,they already used resources to build them why throw them away to get a window that takes more resources to build and will take 60 years to pay off with the energy saving.
thats cuz Acorn and the Bugs Bunny and Tweety show were the other entities that voted:eek::D
didn't think you were, but it was comical :face-icon-small-dis:p
is this true?
spomey
yes. and you are going to pay tax on the money you already gave them, so you math is actually about 10% low:beer;
is this true?
spomey
This is why I will never own a GM product again, unless its antique.
Ford is my new vehicle of choice.
Not even close. Spomey is a conservative and has been worried about these trends for as long I have known him.
TRENDS ???? what are you guys fawking completely RETARDED ?????...like my GOD MAN !!!! the world as we know it has gone to hell in a hand bag and you panty waist sons a *****es are talking trends
like what kind a fawking slip tit ............waist of skin fawking basterd doesn't understand that Barry Obama ..is a true socialist pig from hell .....furthur more do you not know that the same prick just sold your rights and beliefs down the fawkin river like the rest of the thinjgs that we ....that's we all held true to our hearts as being a Christian nation GOD FEARING People !!!!!!!!!!!!!!
like wake up MAN !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have known Spomey for 15 years and I have known of him for 24. I also know his dad. That pre-dates Obama. The disease of large government has been around longer than me. In my life, I remember, Jimmy Carter, Tip O'neal, Bill Clinton and all those who followed and Johnson's big idea before them all. I remember the supreme court decision that made it legal for government entitities to use eminent domain to take land from private citizens and give it to Walmart and that happened during the Bush administration. So you see, It is not only about Obama, but a trend in which groups use the tentacles of large government to redistribute wealth as they see fit. It can go to big labor or big business, but it is certainly away from me. If it took Obama to wake you up then you are truly behind the 8 ball.
Karl
Karl
not likely scooter ...................................BECAUSE HE IS THE ANTICHRIST and that my friend is way dated ....have a nice day ..........and if you know anything ..H2SNOW has been predicting this sh1tr for a long long long time .............perhaps you should take an hour and do some research ...start with my name and all of the stuff that I have been preaching for years ...........next
No, not the antichrist. The antichrist would have to be smarter...I am not sure why I would take time to research you. Your voice is as small as mine and just as unimportant. I don't doubt that you are a conservative, however. But, I would not under-estimate Spomey either. Keep up the good fight my friend. But remember, it is not democrat or republican, it is a less invasive government we are after.
