ya sry, i ment grid heater not glow plugs. Also could always by a new truck and do the EGR and DPF deletes, just did them on my brothers 2007 dodge and gets better mileage and more power.
Another vote for good batteries most of the batteries from the factory are junk and way to small for the application. Run additive and plug in if you can but if you can't oh well. Try and park it out of the wind that helps quite a bit.
I've never noticed a problem with wind one way or the other. Vehicles don't feel wind chill, only actual air temps....Only reason I try and stay out of the wind is so it doesn't get covered/packed/surrounded by snow.
One thing nobody has mentioned is OIL. Good luck starting your truck in the cold with 15w40 summer oil. I run 0w40 all winter long and have started the truck all the way down to -40(c or f) and it hasn't left me stranded yet. It sounds something aweful and you might want to keep it from going into high idle for a few minutes when it's that cold.
Yes and no. You are correct it can't get any colder then the actual temperature but it will get there a lot quicker if you park it out in the wind. With our semis if you park them outside in the wind when its 0 and -20 with windshield parked in the wind by morning they turn over pretty slow. If we park them inside our uninsulated shed that is the same temp as outside but out of the wind they start a lot nicer.
Yep, I agree now that I think about it some. I just thought you meant parking outside in a parking lot or something like that! Something about that shelter DOES make them roll over that much better. It's like that up at my inlaws, uninsulated machine shed (door open) and the vehicles DO roll over that much easier in the morning when it's colder than a witches brass tit. Gotta love ND, huh?
What is HEUI injection? Is it on the newer trucks or the older trucks?
Let them run my 6.0 has been running for 4 days, -40 here plus a wind.Can someone post a link to testing the glow plug relay on a 7.3L ford.
I have always ran Rotella 15w40 even in sub zero temps and have never had any problems. And I have honestly never seen 0W40 on the shelf....intresting, I'll have to look next time.
