I'm sick of the puddle of oil under my sled. Rather than trying to keep finding the leak I'd rather get rid of the bottle and the pump. Is this possible and what steps do I have to take to do this. Sled is a 04 800HO Skidoo Rev
yes it is possible, many have done it.
http://www.dootalk.com/forums/index.php?showtopic=164998&hl=oil+pump
I have heard of leaving the oil pump and adding a small hose filled with oil and a cap. dont really know how this works. the cover plate sounds like a better idea to me. maybe changing the oil behind the plate once a year. the only downfall is having to use premix on the hill. cant borrow any gas unless you have oil. Anybody know what 40:1 is per gallon of gas. i hate math
Thread is not there anymore?? I just clicked on it and it's there.
Try this one.
http://www.dootalk.com/forums/index.php?showtopic=164636&st=15&p=1366623&#entry1366623
Look up Ttab's mod shop on Dootalk, shows step by step how to do it.
Thanks. That one works.
Actually I lied. The post does'nt seem to be there anymore. Anyone else care to help me out please? I cant find any info anywhere on the net. And as for my dealer, well I took a peice of broken jack shaft in to ask a question and they did'nt even know what it was. So I kinda have no faith in the dealership in my home town.
Taken directly from the link I provided
Ski-Doo 420810825 Cover Plate (block off plate)
Ski-Doo 420931565 Gasket (for block off plate)
Ski-Doo 420956240 Oil Tank (not needed but im using it anyways)
Ski-Doo 420960279 Closure Cap (little black thing on the bottom of the tank, refer to Nikolai's picture)
Ski-Doo 420951260 Clamp (for oil hose)
Ski-Doo 420951240 Clamp 12 (for little black thing)
Ski-Doo 420956239 Oil Tube
Ski-Doo 420874370 Fitting (changes from oil tube to hose which goes down to motor)
Ski-Doo 512060141 Ecm Support (bracket that pull cord, oil tank, and ECM mounts to)
Ski-Doo 271000110 Protector Trim (protects water hoses from getting punctured from bracket)
Ski-Doo 207662544 Hex Flanged Screw M6 X 25
Ski-Doo 233261414 Elastic Flanged Nut M6
Ski-Doo 207561244 Hex Flanged Screw M6 X 12, Scotch Grip
Ski-Doo 518324951 Plate (ECM sits on this)
Ski-Doo 570069700 Latch (holds ECM)
Yep, exactly what you need ^^^^^ my only question is this.....is there a coolant reservoir out there that does not have the nipple for the carb heater?
Sweet avatar. dunno about the coolant bottle, the 440 has a different PN though. Excellent pics Premix setup, mirror image of mine, except a little cleaner.
The air temp sensor wires will need to be extended due to MPEM relocate.
Is there a coolant reservoir out there that does not have the nipple for the carb heater ?
Dunno about the coolant bottle
Thanks I'm kinda fond of my avatar too....lol. I did not know that about the air temp sensor wires for the HO, on the 07 the ECM drops right in, nothing to change on the harness.
Do you have a belt drive on your sled?
I hate math
So let me get this straight, im a little confused.
You can take the oil pump off and block it off with a plate and then you just mix your oil into the fuel.
My questions...
* 1. Does it affect the performance of the engine ?
* 2. How does it keep the bearings lubricated so that there is no crank problems/failures ?
thanks for the help/ advise
ben
