I also came out to a low battery? the other morning after 4 full day rides with no issue.
I have a lightweight Shorai Lithium ...
It had only sat over night in the garage, but was very cold (below freezing).
I was wondering if the kill switch would make a difference since I think it was in the "run" position?
(update) I have not used my sled since it was slow to crank over, so I went and put a voltage meter on it. 14.08, which is approaching 100%.
I am blaming it on a very cold battery. I just went and cranked it over now and no hesitation ...
If it is very cold, it might also effect the battery performance. (per the mfg)
The Q&A site
http://www.shoraipower.com/s.nl/it.I/id.5/.f for my Shorai battery suggests "warming" the battery with usage:
Q. I hear that lithium crank poorly when it gets cold, is that right?<O</O
A.Lithium do increase in resistance more as temperature drops, compared to lead-acid. However, they also react to cranking under cold conditions in a much better way. Lead-acid will increase resistance on each subsequent cranking attempt, until it won’t turn over. If your LFX fails to start the engine on first crank, that first crank has warmed the battery, and the second attempt will be much stronger, and so on until you get a good start.
Shorai LFX are much better in cold-weather conditions than other-brand lithium starter batteries, due to our eXtreme-rate formulation with low resistance. Down to about 20 degrees fahrenheit (-7C) most users find that they can start normally on first crank. If your headlight comes on at key-ON, it is good for the batteries to flow some current before cranking in cold weather. The suggested headlight-on time before cranking depends on the temperature. If starting at 40f (5C), 30 seconds will help wake the battery and increase cranking performance. If at 0f (-17C), leave the lights on for 4~5 minutes before cranking. The result will be a better first crank, and longer battery life. Any other accessories that can be turned on before cranking can also be used for this purpose, such as heated gear, radio, etc...<O></O>
<?xml:namespace prefix = "v" ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 title="Stick Out Tongue" class=inlineimg alt="" border="0" src="images/smilies/tongue.gif" smilieid="5" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o</v:shapetype>
Q. Can I use Lead-Acid battery chargers or charger/tenders?<O></O>
A.Yes. HOWEVER, you may NOT use a charger/tender if it has an automatic "desulfation mode", which cannot be turned off. We have confirmed with Deltran, makers of the "Battery Tender" brand, that their products do NOT have a desulfation mode, and are therefore OK for use with Shorai LFX, for example. But the best possible charger/tender for Shorai LFX is the SHO-BMS01, which will be released on about March 15th 2011, we expect. It uses the 5-pin BMS port in the LFX batteries, in order to monitor, diagnose, and balance the individual cells during charge. And it also has an optimized storage mode that will give the longest possible service life to your LFX.
If you are storing your vehicle and want to check the remaining capacity, or you're a racer with a constant-loss system, you'll want to know how resting voltage (i.e. with no load or load under 200mA) maps to remaining capacity. LFX batteries should be maintained such that 20% capacity remains at minimum, as best practice. Use a good-quality voltmeter to check remaining capacity, and consider recharge whenever the battery capacity falls to about 50% remaining. Of course, if you get the Shorai dedicated BMS01 charger, you can just hit the "Store Mode" button and leave it to do the work for you.
The voltage chart can be found here: http://www.shoraipower.com/s.nl/it.I/id.5/.f
