I was able to get everything hooked up tonight and I figured I would post some pics for anyone else looking to do this.
I used the UB1213 battery that was posted earlier in this thread. One of the main reasons I didn't want to use a battery was that I didn't want more components in the way for when I needed to work on the sled. I'm trying to keep things as simple as possible. But, as I turns out I needed the battery. After kicking around many different mounting locations the spot I came up with that would protect the battery, hold it tight and keep it out of the way was the factory tool pouch on the left side of the sled. The battery fit perfect in there and I can still fit the spark plug wrench, belt change tool, emergency start rope, and 2 stark plugs in there as well(not in the pouch anymore). I picked up a waterproof relay, a fuse holder and used the harness I got from off road rider. I didn't use a "fuse block" like others posted. I wanted all of the components on 1 fuse so I know that if my a/f & egt gauge go out that I lost power and my turbo oil pump is not longer getting power anymore either. I didn't want to add a "dummy" lite for the oil pump.Once again trying to keep things simple.
I'd still like to come up with a smaller battery, but I don't know what I could use that would be smaller. Anyone have any ideas?
I haven't gotten to actually ride the sled yet, but I did make a couple immediate observations from running the sled in the shop:
-The sled starts up so much nicer. Over the summer the only changes I made to the sled where that I installed a new fuel pump and the EGT gauge. I assume the EGT gauge doesn't take much juice to run, but my sled started noticeably harder this season. Even when warm. It would take 2-4 pulls to get it to start when warm and sometimes up to 10 when it was cold in the morning. The sled now fires on the 1st pull everytime.( I havent gotten to try it cold yet). I'm assuming this is because the fuel pump and ECU are now getting the needed power to actually work properly on the 1st pull.The other thing is my sled has always idled low. Dash would be flickering, battery light would sometimes flicker on, sled would run rough. Now my sled is able to idle a 1400-1500rpms(yes I know this is low) without the dash lights flickering or the a/f gauge giving my the E9 low power error.
Any questions let me know.
