Cutler Stage 1 turbo with BB ??
spag900
Is it possible to run Cutler's BB 950 on a '10 M8 that already has the stage 1 kit on it??
big bore
I would call dale, he would know better than anyone else. he also will probably have good advice about the build also.
No reason you cant do it, I cant speak for that exact setup but there are lots of BB turbos out there running strong. Just I agree on calling him, he knows better then anyone on this forum.
Unless its an upgraded turbo the standard 2860 on that kit is going to create a lot of heat. aka issues...
BTW, big bores and Turbo's work awesome IMO. Way better bottom end and reduces any lag even more so. Kinda like putting a supercharger in front of your Turbo ;-) Like it so much on my TM1200 I want a BBK on my TM8 on propane now.
Pretty good on fuel from what I found either way, way, way more torque on the bottom when you roll off the throttle and get back on. Doesn't feel like you have to spool up the turbo as much for the big climbs and you can roll out mid climb without falling off the power and trenching out. More responsive on the trail corners as well and smooths out the "hit" of the boost making it more of a linear feeling. In a sense it makes the sled more rideable without people being afraid of the hit when the turbo spools up...
