T
I'm going to assume the lack of response means no on-snow testing has been completed?
Will get my kit in 2 weeks in sweden, just worried about the warranty when the 850 engine blows up, maybe it depends on dealer if that will be a problem?I wonder when they are going to start shipping them. Anyone get a kit yet? I ordered it back when this was first posted...
Your best bet might be to call them?
Just curious, what did you make the cut with?Got my tunnel mostly finished up. Cut 6” off of my 163 tunnel. Mounted the bumper 1” further in then stock (the kit gives 2 mounting options). Process went relatively smoothly, just be sure to take your time. Definitely stressful to make the cut! My heart was pounding when it came time to chop my 1 year old sled!
I used a 5” aluminum zip disk on a grinder. Worked well enough. Ideally an aluminum blade on a circular saw would work better. But those blades are pricy.
How do you keep the aluminum shavings out of the radiators and engine?
I hope that rear support is strong enough because that crossover coolant section imo is what holds everything together back there so when you cut that out and only add a thin plate to cover the hose I’m thinking you lost strength only way I think to add some back is a strong aftermarket bumper
