I think this is why I am running like crap, no changes other than went to the TSS intake pod, and it isn't giving me enough air. Haven't tested enough to prove it though.Also ensure you have enough air. Last year i had a outerwear's cover i made for my airbox top. I then also had a plate deflector on the back side of my airbox (keep the TS from shooting snow all over the filter) with the bottom of the airbag cut out all the way around. I thought i had a jetting issue. After scratching my head i removed the deflector and exposed the entire filter and removed the outerware cover. The bike instantly ran perfect ever since. The Pulse requires a lot of air !
My riding partner who also has a KX500 ran an intake similar to the Timbersled early last season. We found that it would accumulate too much snow around it in the deep and would choke the motor. My intake didn't seem to have that issue so we made another one. Its a longer intake that draws air from further back and higher up, out of the way of the massive amount of snow that gets packed in near the motor.
You mean, did I see those issues with this intake? Nope, its 2.5" intake tubing and tons of surface area for the intake screen. Flows a heck of a lot more than the stock air box, especially when running a stock foam filter.
If you think the Timbersled intake is causing running issues because it doesn't flow enough by itself, that's probably not what's going on. As long as it doesn't have a bunch of snow packed onto the pre-filter, it should flow plenty for the 500. If you're saying that it ran better without it, maybe its causing some sort of turbulence near the venturis or something.
The only change made was the intake and it started running extremely rich. I'm going to do some testing tonight, pull the sock off. Maybe something else is going on, see if I can figure it out.
I was expecting more flow out of a prefilter set up too.. So it is odd to me.
OK. After today I'm changing my tune a little bit. Today was really deep,really light, and really cold. I could not hold temperatures at all. I dropped down to as low as 60° and had trouble getting back up above 80 or 90 in the deep snow. Not only that my bike ran like chit. The carb heater could not keep up. It just iced over and didn't stay warm enough. I had a wicked bog that would go away at the very top end but was there consistently when my temps were low and my carb was covered with snow and ice.
I have the neoprene carb Cover from avid. I'm gonna try it out this weekend when I can ride again. Though I don't see how I can possibly fit it over my carb--things are a bit tight in there! Hopefully I find a way. I'm also going to build some shrouds. Hopefully this helps.
on deep powder days not a chance in hell i could keep my cr5 temps up without a thermostat. and i have lots of shrouding
Sorry. Thought i mentioned it somewhere. I have the avid t-stat with the bypass going to my carb heater.
