what sled and what year..the following is 07...probably the same
Check Engine Light
(Crossfire/F-Series/
M-Series Models)
The Check Engine Light is controlled by the ECU and
may illuminate for a number of reasons. The light
should illuminate each time the key is turned to RUN
or START, and it should go out when the engine starts.
If the light stays illuminated or it illuminates while the
engine is running, the ECU is receiving input that is
outside of its established parameters.
Diagnostic Codes/
Check Engine
M-Series Models)
These diagnostic codes are flashed by the check engine
light incorporated within the speedometer/tachometer.
Refer to the following chart for diagnostic code
sequences.
NOTE: On single-digit codes (2, 4, etc.), the number
indicated will flash in an uninterrupted
sequence. On double-digit codes (1-2, 1-6, etc.), the
first number indicated will flash in an uninterrupted
sequence, there will be a short pause, and the second
sequence.
If the coolant temperature is at or above 80° C (176°
F), the coolant temperature light will flash a warning
(alert). If the coolant temperature is at or above 93° C
(200° F), the coolant temperature light will cease flashing
and will remain constantly illuminated.
Number of Flashes Trouble
1-2
(Check Engine Light)
Failure in ignition coil.
1-6
Incorrect adjustment/failure in
APV cable.
1-7
Failure in exhaust temperature
sensor.
1-8
Failure in servomotor.
2
Failure in injector(s).
2-1
Failure in knock sensor.
2-3
Failure in knock control system.
4
Open or short circuit in barometric
pressure sensor.
5
Open or short circuit in intake air
temperature sensor.
6
Open or short circuit in water
temperature sensor.
7
Open or short circuit in throttle
position sensor.
Steady Flash
(Coolant Temperature Light)
Coolant Temperature Above 80°
C (176° F).
Constant On
Coolant Temperature Above 93°
C (200° F).
Chassis Control Unit
M-Series Models)
The Chassis Control Icon may illuminate for a number
of reasons. The light should illuminate each time the
key is turned to RUN or START, and it should go out
when the engine starts. If the light stays illumintated or
it illuminates while the engine is running, the CCU is
receiving input that is outside of its established parameters.
Diagnostic Codes/
M-Series Models)
These diagnostic codes are flashed by the wrench icon
sequences.
NOTE: On these double-digit codes (3-1, 3-2, etc.),
the first number indicated will flash in an uninterrupted
the second number indicated will flash in an uninterrupted
sequence.
3-1
(CCU Icon)
Stator failure
(input open or shorted).
3-2
(CCU Icon)
High power DC output deactivated
(headlight/handwarmer).
3-3
(CCU Icon)
High power DC output shorted
3-4
(CCU Icon)
Low power DC output deactivated
(gauge/taillight/APV valves).
3-5
(CCU Icon)
Low power DC output shorted
3-6
(CCU Icon)
System under voltage
(below 11 volts).
3-7
(CCU Icon)
System over voltage.
(above 15.5 volts).
3-8
(CCU Icon)
Gear shift actuator failure
(over current or over temperature).
4-2
(CCU Icon)
Tachometer input failure (engine running
- no tachometer
signal present).
4-3
(CCU Icon)
Gear position switch failure (did not
change - no (or invalid)
position input).
4-4
(CCU Icon)
CCU over temperature
(above 105° C - 221° F).
