I would say its time for a new top end. What elevation are you at and are you holding the throttle wide open while you pull it? Also I'd try to check with at least 2 different compression testers as they can vary radically. My 05 rev has a high comp head with about 700mi on the new motor and my compression was 155 and 149 at 4600ft. Not sure what the comp should be on a stock head though? Also I would suggest doing a top end every 1500-2000 miles.
