Colorado For Sale, want to buy, jobs and services
5.00 star(s)
White and black '12 Pro seat
Listed for 165$ with underseat bag
150$ without
(720) 347-5221 call or text anytime!
R.P.
Annnnd, wanting a Pro original white hood, I've painted my black one white but would rather an original, so if you have white and want to paint use this one instead!!
Thanks
Trailer that doubles as a portable shop for sale
I am selling my towable shop:
Specs are as follows:
2012 Double R custom built "All Sport" Trailer.
Year: 2012 Make: Double R Model: 8629AS7K
8'6" x 29' All Sport, 24' Box, 7' nose
GVWR: 14000# 2-7000# 8-lug axles, ST235/80-16" Radial Tires, 4-Wheel Brakes
Aluminum Wheel Upgrade (Set of 4) - Spoke Style
8 Lug Aluminum Spare Tire Pkg: Installed p/s up high rear
4' beavetail
Sloped interior fender wells to be drive on/drive off
Additional Height to Acquire 7' Inside Height (per ltf)
Grey Vinyl Wall Liner I.L.O. 1/4" Plywood
White Vinyl Ceiling Liner
Insulated walls and ceiling
2" Insulated Floor Per/SQFT
42,000 BTU Forced Air Furnace Non-Ducted
Includes: LP detector, wall thermostat, deep cycle battery, cabinet built around furnace to accommodate furnace only.
10 Gallon Propane Pkg., Each Tank is 40 lbs - installed on tongue
Includes: Dual 40-lb (10 gallon) Propane Tanks, Bracket Auto Changeover Regulator, Hoses,Valves, LP Detector
110 power pkg w/50 AMP Service
Includes: 50 AMP Breaker Panel, 50 AMP Service cord, 4 - Interior Duplex
Receptacles, 1 - Exterior GFI Duplex Receptacles, 4 - Dual Bulb 48" Fluorescent Light
Fixtures, Single Light Switch
4 Exterior Load Lights (12V)2-front ramp, 2-rear ramp wired for back-up lights
Upper and Lower Nose Cabinets
Add structure to lower cabinet to accommodate Vise to be installed by customer. Install plate on end furthest from nose on Pewter counter top.
24" x 20" windows tinted w/slider and screens 1-side door on d/s, 1-centered in
between fuel doors on d/s (normal height location), 1-3' from straight wall on p/s, 1- 4' from rear of trailer on p/s
Nudo Flooring
2 Fuel doors
1 Wire for A/C in both 14" camper vents
Generator Compartment in lower nose cabinet w/generator door, vented bottom - See
Cummins Specs for Gen. Size. Customer to install Gen
Automotive Undercoating along any exposed underside steel and tongue
Steel bracket to work as winch for snowmobile rated at 500# capacity
E-Track Recessed on Wall 2-rows on each side wall, 12" from floor, 48" from floor
40 Gallon Fuel Station/Fuel Cell for Generator
Includes: Fuel Pump, Deep Cycle Battery, Fuel Gauge, Gas Hose, Nozzle, Lockable Storage, gas line to generator compartment
1 Diamond Plate Trim 6" high going down both sides of interior walls
6" tall diamond plate on interior side walls
8" Trim Package - Exterior side walls
16 Exterior L.E.D. Marker Lights 8 additional down both sides of trailer
4 Motorcycle Wheel Chocks Recessed
Onan Marquis Gold 5.5kW Gas RV Generator Installed w/remote start, wire harness,control panel and hour meter.
Color: Black front and Roof/Bright Annealed Stripe/Red Rear and Rear door, Black
2 D-Rings 6K# Rated Recessed Swivel
9 D-Rings 1200# Rated Surface Mount
1 Centerline Equalizer Hitch and ball, w/welded on brackets
Brand new set of tires, everything in perfect working order. The reason I am selling it is simply because I do not need a trailer like this any more and I'd really like to have my truck a lot closer to being paid off than it is right now.
$18,000
PM if interested.
VP110 for sale $8 per gal
I have a drum of VP110 that was bought in Oct. 2013. I have switched to AV gas and need to empty the drum to use for new fuel.
$8 per gal. must have own containers.
Brad's Conoco in Lakewood has the ethanol free. Have been running it without any issue. I have talked with him on several occasions and they say they are selling a lot of it and keeping it fresh. I haven't had any Det codes even with my high compression head installed. Price as of 03/06/2014 $439.9
SOLD .................Steel sled deck with ramp and tie down clamps. $700.00 in Colorado Springs
Welding Needed Small Job $$, Colorado Springs area
Hi,
Figured I throw this out on this website to see if someone can help and earn a little extra money doing so.
My camping trailer dropped its water tank on our last Camping trip this past October. I dropped the coroplast to see the damage today. Both welds failed on front 1.5 inch angle iron and one weld failed on rear angle iron that holds the water tank in place.
Need someone who can weld new angle iron onto the camper frame. Some mild grinding may be required. I am heading out to get some new angle iron and some "L" brackets and will use self tapping sheet metal screws to get everything back in place and prepped for welding. The tank is currently held in place by my floor jack.
If someone here would like to earn a little extra money, let me know. If you come to my location, I feel that $150 for the welding job is a fair price ($100/hour for estimated 1.5 hours work).
Thanks for looking!
Drew
Selling my 12 M8 Limited. Season is about over for me and just gearing up for summer. This sled has been 100% flawless! Just broke 1400 miles last weekend all on same belt. All updates have been done. Not a belt burner. All stock except for a BMP can.
19/50 gearing (2014)
Stronger primary spring
Clutches updated to 14
BDX front bumper
PDP side panel vents
BMP Can
Always stored inside a trailer or garage
It's been pull and go since the day I bought it. All I've done is maintenence and cleaning. Only selling because I have to boost fever and buying my buddy's boosted 13.
$7500/OBO
Sent from my SAMSUNG-SGH-I537 using Tapatalk
