Cluth Adjustment?
I need a couple pointers on the right way to set belt tension. They say to put chords flush with edge of secondary but it seems to tight and creeps a bit to much. What will I give up if I back off the tension and sit belt into secondary deeper? I'm far from being a cluthing expert and could use a couple suggestions. Also, is there supposed to be one limter strap or two? Looks like there is a spot for two but I only have one on the left side and there is a bushing of some sort in there that is loose. Looks kind of goofy but never noticed it before. Maybe that is how it's supposed to be. Also have had a little coolant on the floor of my trailer 2 different times. Hasn't dropped the level much but is still a concern if it is leaking or just overflowing after being warm. Anybody else seen this? Thanks for the info!
Go to the website, sledshot.com and click on tech tips. I just watched a great vid about installing and adjusting belt height on there. As far as the limiter straps go, my 04 800 has two. One left and one right.
Run the belt as high as possible without creeping or squeeling. Belt height is just a general guideline as the center-to-center and belt dimensions will vary.
There is only one limiter strap.
