Clutching - Clutch - Clutch temps vs. Engine rpms
Dynamo^Joe
Klim Ski-Doo HMK Trygstad Motorsports
Clutch temperature...
Regardless of temperature whether it is cool or incinerating temp; the lowest temperature revealed will be when you can run the engine at it's rated rpms.
Rated rpms: The rpms the engine makes its maximum horsepower at. 800R = 8150 rpms
If you run the engine higher than rated rpms [example 8400] the system temperature will increase.
If you run the engine lower than rated rpms [example 8000] the system temperature will increase.
So regardless of temperature you measure, whether its hot or cold or warm or burning or freezing - The lowest temperature you'll measure is when having calibration allow the engine to run at "rated rpms" on a sustained wide open throttle pull.
You will find and efficient clutch setup will reveal temperatures;
Hottest temperature is on primary stationary sheave [engine sheave]
Next coolest is the primary sliding sheave
Next coolest are the secondary sheaves.
Some will even find that primary sliding and secondary are cool vs. the engine stationary sheave.
The combustion heat is transmit through the crankshaft into the crank stub and onto the stationary sheave.
The sliding sheave is disconnected from the engine, the disconnection is at the inner sheave bushing....little if no heat will transmit through a bushing - the heat transfer goes through the belt.
Heat in the primary is caused by the belt moving along the sheave faces at a slower rate than full capacity and usually when the engine cannot run at its rated rpms.
If you are calibrating the system to run the engine at "rated rpms" - The belt will travel along the sheave face the quickest when the clutches are calibrated to run at rated rpms. Lower or higher than rated, the belt will not travel at the optimum rate.
that explains it!
Blah, It is sad that the TRA3 is a better clutch than the new design, BRP is going the wrong direction and generating a lot of heat. :face-icon-small-dis
Interesting!
That is an interesting read Joe, Thank you.
Joe, if the Revs, and XP's are clutched properly, do they need much venting? I see so many people over venting... I am wondering if that is a band aid to a deeper problem? I myself have some vents in the back behind the clutch, and they do more than enough to keep my air cool under the hood.
Speeds
Are you saying at WOT that the least heat is at 8150? Why is there more heat generated on the clutch at a lower rpm? What about running partial throttle at say 6500 rpm, wouldn't that be a lower heat rate too?
I believe he is stating upon a WOT scenario, where most heat occurs.
Joe, thanks for taking the time to talk to us on the phone the other day. Can you tell me how the primary is working with your clutch kit. Does the belt make it farther up the primary than with the stock clutching ? Just curious
