Clutch recall
Both my p-22’s had oil in clutch tapers. Torque every ride 100 ft pounds i think its tightened two full turns in 600 miles. It came from the dealer loose 58ft pounds to break loose not good! This is what 20k buys. A bunch of garbage parts!
its probably closer to the cat stats. Still suspect its the bearing in the clutch. cat guys wont just go back to the 17 clutch tho, why? better than a p-85 in my experience so far. i replaced a couple cracked p-85s on wedge chassis in the day, never exploded one tho, just precautionary replacements. only reason i said better than p-85, just my experience so far.
And you did the right thing replacing the cracked p-85s. It's better to ride safer. I had a case where I didn't do a timely replacement, then had to pay more later.
Hi, all. I see it's very interesting here.
any word on a fix?
I find it interesting that i received a notice for my 9R and 850, but not my Boost? is the Boost not recalled? If not, why? Thought it was the same P22 as the 9
any word on a fix?
Because the other active "stop-ride" on the Boost would make the P22 stop-ride redundant. Gotta let them figure out one problem at a time
I found a deal on a 2023 9r that someone backed out on and ended up going for it. Unfortunately can't bring it home until the clutch recall is complete. As of now, dealer hasn't heard when a fix might be available.
Have them remove the clutch
Sent from my motorola edge plus using Tapatalk
I got the handle bar hook stop ride thing too. Signed up to get the new hooks. Looks like a simple install. :)
I have had no clutch issues so far, or any other stop ride notice problems to date! I know of 2 skidoo sleds that burnt down last winter in my area, proud Doo owners too.
Brand bashing BS is old AF. I’m glad I ride what I like and want to. Patriot 850 sks and 650 SBXC, a doo 850 as well.
Has anyone heard or have information on the Clutch recall? Fix related is it a New Clutch/Repair? P85 interest mostly, I would think they would release something at the same time for both.
