Clutch Help
J
Dec 28, 2019
1
2000 600, ton of miles on the sled but just did a brand new top end. Runs strong but only pulls 7100 rpm. Clickers on 4 so can’t get much there.
Assuming the clutches are wore out and need refresh. Anyone with suggestions on where to go? Anyone make clutch kits still? Ride 6-10,000ft
wyox
New member
125
4
18
49
I would start by pulling your clutches apart and cleaning them. Replace the bushings and springs with what was in there.
B
Sep 24, 2009
605
136
Yakima Wa
in addition to the clutch work, take the caps off your rave valves & make sure they slide smoothly. If not, loosen bolts & reposition housing. The valves can bind if not centered properly on install.
ZX Guy
New member
32
3
8
55
At one time dynamo joe was the guy for clutch kits. I’m still running one of his in my 03 Summit 800ho. you should be able to buy a clutch rebuilding kit still. I did that in the wife’s 01 800 summit And clean everything up really good.
