The "Carls helix" everyone talks about is what you want. Top of head its
64-42 .40 on one track 62-40 .40 on the other. Gives you two options in one helix and both tracks work great. One in deep pow, the other in heavy wet snow.
Order it from Carl's on-line is easy. Bunch of other vendors or classified are worth a look too. As for your marks, if that was a typical riding day and you say you went 78mph you can gear down, one or two teeth on the bottom gear. Everything will improve, belt life, throttle response, track speed in the deep pow and you will likely not suffer any top end loss at all, that's what you have now, your not using all your transmission. Your belt will move about about half the distance of the marks that are left, more or less. Set your belt side clearance in the primary to 0.015 -0.020" (important and often way off)and run your belt tight, close to squealing or creep on a stand. Enjoy, it will all be a noticeable improvement.
