Clutch? Belt Removal
You take the allen head bolt out and the clutch should come off the shaft. The piece with all the holes in it adjusts your belt deflection. Set it where it is good and then tighten the allen bolt to keep it set.
If you just want to change the belt you don't need to remove the bolt. Just twist open the sheaves and pull the belt off.
