I'm no expert, but after looking at your video's I have a couple ideas and input. They are separate things, but when put together, they willl make a big difference.
1. Get a handlebar riser. You're way to bent over to be able to make the quick adjustments you need to make while climbing, ie; rapidly shifting your weight from one side to the other to keep your center of gravity.
2. I think this one will cure itself with the bar riser. Your foot is all the way at the back of your running board when you started your climb. You are creating a wheelie before you start the run. Start mid running board and adjust as needed during the climb, (a more upright stance with the risers will help achieve this also).
Stand with your feet just behind the foot wells with your arms at your sides. Raise your hands up a bit so they are level with your jewels, That is about where your handlebar grips should be.
Correct bar height will make all the difference when you are trying to shift the sled around while riding. The way your bars are now, with your body positioning is all wrong to be in complete control of the sled.
Thats my .02 cts, Hope it helps
learn how to carve downhill turns so you can at least try to miss whatever you screwed up and aimed for after turning out.
I'm reading some good information.
Doing a pirouette on the tail of the sled to point it back downhill comes much later..........but it is damn fun.![]()
