cleaning rev side pannels
I won't comment on any of the other cleaning advice on this thread so far, but the best product that I have used is called Plexus plastic cleaner. My friend has a yellow XP with some stains on the side panels that looked new after cleaning with Plexus!! can be purchased at most sled/motorcycle shops.
X2 but its expencive brakeclean also works good to buts not the best for you
Believe it or not, I've had alot of luck using the Mr. Clean eraser sponges on dirt, grease and scuff marks - especially on the doo yellow. It takes a bunch of rubbing and you go through the sponge quick, but it does work. Good luck.:o
Ive tried that on mine with the same results Mr Clean erasers works well. skip the castrol wax and grease remover that dosnt work at all.
I use the BioKleen sled belly pan cleaner and a scotchbrite pad. Was really surprised when I used it, works really good on dirty yellow panels. I bought the sample kit and out of all the products in the kit the belly pan cleaner will be getting a reorder from me.
