Any one tried Precision Efi?? It says it will add around 8hp.
Assume pipe mod requires fuel controller?
Do you have dyno runs for this kit as is and with the pipe mod by chance? Would be interesting to see.
https://youtu.be/t11kAbHoUOw
This is my Alpha with a SSI y-pipe SSI titanium can and SSI clutching. The T3 is a 174 with a 9115 3”, ported and polished and head work from split second. Clutching from Racers Edge. The BDX SSI combo is killer.
What are you running for weights with the y pipe?
Looking at doing the Y Pipe as well as pipe.
based on my past experiences on my 09 M8 and my 15 M8000. I would be adding looking very hard at this as a start.
https://www.startinglineproducts.com/snow/arctic-cat/exhaust/arctic-cat-800-pipe-set1-8021.html
I addition I typically add either Boyesen Rage Cages or V Force Reeds, a high compression head and MDS clutching to match.
Or
to knock it all out in one shot: Saves 21 lbs and adds 21 horsepower.
https://www.startinglineproducts.co...its/stage-4-for-2018-19-arctic-cat-m8000.html
As a secret trick and to get your other 4 horsepower. I add this to most tanks of gas.
http://www.klotzlube.com/power_additives.html
I also have these in each of my sleds and bikes: I think it helps keep the fuel from getting stale but, others may think it's snake oil.
https://fitchfuelcatalyst.com/recreational-vehicles
I'm running 2 alphas both 154 first one has light weight seat, tank, hood, mvm belt drive, balanced lighted clutches, full bikeman pipe and silber reflash. This sled feels stupid light and runs amazing pulls really hard and is so fun to ride and gives my other sled thats a turbo a run for its money.
Second sled is alpha 154 light weight seat, tank hood, mvm belt drive and silber turbo running 8lbs and now that we got the mapping right it is incedible and will go anywhere you point it o ly thing i wish it was a 165 because it likes to pack the skis even locked out.
My opinion is it don't matter which sled you decide to ride that day they both rip and have plus/minuses but the more all around sled would be the non turbo. You can ride it 3 days straight in 3 foot powder and not get fatigued and it floats on top so it climbs like a tubo just not as fast but it will get there every time. Now if you were riding deep powder every day all season i would say the turbo is what you want. That being said your only about 2k difference between the two to build them.
Maybe that will help you find your way to 25 hp
