Cheap belly pan hole plug (behind nose cone block off) DIY
C
colin_farrell
Saw that there's still some open holes on the belly pan of the pro and I wanted to block it off similar to the SLP nose cone block off. Went to Home Depot and ace hardware to find something to do it. Found these 7/8" metal hole plugs at Home Depot for cheap. Popped them in the holes and bent a few of the tabs over and fits perfectly. Cheap extra insurance to keep snow from getting in and building up ice. (And yes I do realize snow gets in other areas too)
You chose to plug those two little holes but left the one you can fit your fist thru (between bulkhead and nose cone) un-plugged?
Just ribbing you, it does make it look a lot cleaner. I might do that also with lighter plastic plugs. I got 50 of them for like $10 for plugging the holes I drill in the bottom of the bulkhead to make engine alignment easier (Adjust it via the four engine strap bolts), as opposed to putting the engine mounts in a bind. As the manual says to.
Personally I like the large hole left open as natural convection draws in cold air and the hot air rises and exits thru the MFD hole, once you put a gauge lifter on. I planning on adding a thermostatically controlled fan behind the MFD to help when pure convection is not enough.
