The New 2010 800 is all new and not tested by the public yet but will be as good or better and is going to stomp the competition. There will be a lot of pis$ed off doo and poo guys this year.
Wyoboy1000's post is exactly what I am talkingt about. The same thing happened to mine, 09 bone stock. I think there are quite a few out there with this problem. I am refering to the 2010 motor and wondering if the changes made are a result of this issue.
As far as a M8 piston problem out of all the ones I sold I only had one that had any issue and it was an 09 due to improper break in and we started doing cats break in more thorough and had no more issues.It is hard to do this you think you are going to melt it down.
4. Slowly vary the engine RPM and throttle position
gradually from idle position to a maximum of
6000 RPM until the Coolant Temperature Warning
Icon stays constantly lit while making sure not to
exceed 6000 RPM. Continue varying the throttle
and RPM for an additional 1-2 minutes.
NOTE: Make sure to lubricate the slide rails with
water if you use water it will not over heat like they want or other appropriate coolant/lubricant to prevent
melting of the wear strip.
5. Allow the engine to cool to ambient temperature
(at least 30 minutes).
NOTE: Repeat steps 2-5 at this point.
6. As part of the standard operating procedure, operate
the snowmobile during the first 1 to 2 miles
under 6500 RPM to properly warm the engine
prior to extended wide-open throttle use.
Snowmobiler, there are many 1000's out there that haven't had any issues, I suggest you get educated. The 1000 is a great sled, in my opinion.
