Cat Primary how-to ? ? ?
Anyone have a How-to link on primary clutch removal and disassembley? Also weight changes and spring change?
About to work on a m7 and need some info.
Thanks!
You dont have to pull the clutch to chang weights and spring. Just take every other bolt out of the frunt then hold pressure on cover while taking the rest out.
Also the set screws that hold the weights have red lock tight on them. May need to heat with a torch to get them loosened up.
