The Cast S.C. is prone to some freezing issues. There is an insert that is composite that adds to the equation. The KTM heater "probe" needs to be modified to fit, "length". Corey, "APT", and I have discussed this in length. I have been fortunate to test and tune the cast model in conditions that were trouble free, however they are prone to icing issues. Bottom line is, the billet has the material depth to accommodate the full length probe and no composite insert for the slide. I recommend using the Billet model with two KTM electric heaters. One located at the 10 oclock and one at the 3 oclock positions. I used only one all last season on the KX500 with zero issues. Those two on the Billet carb will be very nice. We are working on an alternative system using a "flow through" aluminum tubing design used on sleds for years. We will have the details this summer and info for ordering etc.
The 2 stroke engine loves to be on the pipe and will pull under a full load at WOT for days. It is very happy being run this way, like our sleds in the past, on the pipe, WOT in the pow for years without even a top end rebuild. We "WILL" get a simple solution to solve the icing issue and the 2 stroke "snowbike" market will break wide open. Compare the number of 4 stroke mountain sleds to two stroke sleds? The 2 stroke has some unique, simple, power to CC advantages etc . We will keep this up front until we get a good universal system for heat.
