carls zero pro or float center shock - which one
8
827revdog
upgrading shocks with carl zeros up front and doing the adjustable rear. not sure if i should do the float or zero pro coil over in the center. i like the adjustability of the float but the durability of the coil over. looking for opinion on which might work better.
If I remember correctly, as of a couple months ago, Carls has a kit that comes with a fox float for the front skid shock and a fox coil over for the rear skid shock that replaces the 2 stock W.E's and uses the stock rear skid components for around $795
I could be wrong but I don't believe they have a fox float for the rear shock using the stock skid components. At least this is what I recall Kasel saying.
carls offers two kits non of which has a rear shock coil over. the econo kit is a zero coil over center with a rebuildible alum rear shock, and the adjustable kit which is a float center and a reservoir rear with compression adjust. they can also mix and match the two kits to suite your needs.
i decided one the zero coil over center over the float with the adjustable rear.
