Shocks front/Rear
Make sure you check the tightness of the air valves on all the Evol chambers and main chambers. If the shocks are covered in oil when you get them this is the culprit. I would still check them just to be sure even if no oil mess. I got 2 full sets of QS3s and all had some with loose air valves. One set I even sent back to Fox and they replaced them and the replacements also had loose air valves. It's a simple 10mm socket and retourque them then no issue. I noticed it when filling them with air when i took the filler hose off the air valve came with it! I think there was a run of them after covid that had poor QC. Otherwise I'm very excited to use them this season!
Thanks for the insight!!
Any idea what the torque spec is??
