Carb heat delete ?
Rixster
While I have my motor sitting on my work bench i think I am going to get rid of the carb heat line. I NEVER use it, and it is a pain when i need to change jeting. It jsut gets in my way. Anyone else do this?
Well that settles it. Actually I was going to do it anyway, just wanted to see what you guys have experienced.
so its not necesary to have it at all, i like.
Pulled all the lines. Tapped the hole in the water manifold and screwed a plug in it. Plugged the bottom line and use it for a drain when I need to drain the coolant. Basically arranged it just like the 03's came from the factory.
while we are on this topic, i just put my motor back in, and was wondering where both ends of the drain hose went, i have one hooked up on the water pump and not completly sure where the other end is suppose to go, right know i have it hooked up to the water manifold, i know thats not where its suppose to be, just wondering where its suppose to be hooked up at.
wouldnt or shouldnt hurt anything having it hooked to the water manifold would it
