80arrow Active member Lifetime Membership Jan 8, 2010 #4 Do you have the front bolt in the rear suspension in the top or bottem hole? Mabye check the air pressure in your rear shock also.
smoking_powerstroke Well-known member Lifetime Membership Premium Member Jan 8, 2010 #5 just put a power claw on that thing!!!
B bamfm7 Free Member Jan 8, 2010 #6 smoking_powerstroke said: just put a power claw on that thing!!! Click to expand... x2 lol
I ItDoAble Well-known member Jan 8, 2010 #8 Did you change the fluid in your hydraulic clutch every 500 miles? If not you're engagement bearing is likely failing.
A ArticDoo Free Member Jan 8, 2010 #9 bamfm7 said: x2 lol Click to expand... a third track? Going to need boost. lol
C cody7thomas Free Member Jan 9, 2010 #10 I have had the same problem here is what you need to do!!! Turbo it put side vents in and maby a lightweight..um... tailight Then it will RIPPPPPPP
