Can you Tig weld an aluminum front inner cooler while on sled ?
Welding
For sure you will want to drain the coolant. Also keep your ground as close as possible.
Depending on the size of your leak? The art of welding is a very detailed process, step by step. Most of the time you will get better results removing the cooler. I would completely drain and then sandblast the welding area. And the do a pressure check before reinstalling.
Happy welding.
