Wow Kraven thanks!!
1) On the voltage reg, what does your gauge show on the dash?? 1 or 2 notches down from the top is close. I will need to check I did know this existed.
2) One and only fuel filter, if in doubt, check it by removing it and trying to blow through it.ck
3) If the pipe sensor goes bad, you get 5 flashes on the dash. no flash at all
4) Did you ever try taking some mini vise grips and pinching off the exhaust purge hoses??? Have done thanks to THEFULLMONTY
5) I'm sure you checked this already, but possible torn exhaust bellows???? been checked and good then lost one and check again and all good now
6) When checking the T.P.S. can/did you use the old needle style voltmeter and throttle up and down SLOWLY and see if there's an erratic reading possible "flat/dead spot on the T.P.S.?????? Yes
7) Has the stator been tested? No but looking forward to this.
Real E-Z to do, here's the specs:
Test the wires coming from the stator (+/- 15% at 20* C) w/sled cold, then repeat when warm:
For the 2008 600cfi/700/800 CFI's
1) YELLOW to YELLOW 0.13 OHMS
2) DARK GREEN/RED to GREEN/YELLOW 15 OHMS
3) DARK GREEN/RED to BROWN/WHITE 30 ohms
4) DARK BLUE/YELLOW to BLUE/YELLOW 2.4 ohms
5) WHITE/RED to WHITE 190 ohms
6) WHITE/DARK GREEN to DARK GREEN 190 ohms
7) BROWN /WHITE to GROUND 0 ohms
8) BROWN to GROUND 0 ohms
+/- 15% at 20* C
Hope this helps
Can we add this to the increasing you IQ this is helpful for me and likly others.[/QUOTE]
On the bold & BLUE , I p.m.'d Monte about adding that to the INCREASING your IQ SECTION as well, haven't heard back, perhaps it'll take a few more requests?????
Cardiac Kid,
One more thought, how about taking an old oil pressure gauge, air gauge, whatever and temporarily hooking it up to the schraeder valve (on the fuel line, by using the old style A/C charge kit line available at auto parts stores) by the air box and duct tape the gauge to the handle bars so that you can monitor the fuel pressure as you're driving down the trail.
Mid to high 50"s P.S.I;. is what you wan to see, whether it's idling or doing 100 m.p.h.
Actually one more idea (I think that's 2 now) , how about either swapping out injectors or having them tested. Usually diesel truck places have the capability to test injectors.
Question, when you had the PC-5 on your sled, WHERE did it run worse, mid-range or top end??
Did you try hooking it back up to see if it re-duplicates the situation since it's an E-Z disconnect /re-connect on the trail?????
Hope this helps.
