prior to honing and upon both visual inspection and inspecting with fingertips the cylinder appeared to be in good shape and ready for honing. After honing, the cylinder reveals scoring that is both visible and easily detected by touch and now it is recommended that the cylinders be replated. technician did not even proceed any further to measure cylinder to piston clearance and ring end gap which was the sole purpose of leaving cylinders and pistons.
Does this seem likely?
does anybody have any experience with this type of a situation?
it seems strange that they would have proceeded to hone the cylinders in the first place if they felt they were needing to be replated unless he felt honing would solve the problem?
Is it possible the cylinders could have been damaged when measuring piston to cylinder clearance or setting ring end gap? I had also asked that they check for the holes for roundness and straightness.
sled is a 2010 800 RMK. Will have after-hone photos next week. Should have taken pre-hone photos before dropping off cylinders but did not.
