Camper generater ?s
Z
zr600
I want to get a genarater for my camper. Just would like to know what size i really need, i want to be able to run the fridge lights and air conditioner if i had to, also would be nice to have it for a few backup things at home. I'm considering the honda but don't know which one. Is there any other brands to consider.
Honda or Yamaha are both great and pretty quiet. To run a/c you need a 3000. Linking kits for two 1500 are nice to so you don't have to lug the heavy one around
on my camper to run ac you need 4000 watt continous not just surge, got a 5250 sears with the 6 gal tank, big but i charge trollin motor battery's and other stuff while the women have the ac runnin without worry
buy a champiom 4000 from Schucks for 299.99 , it will do all you want and for the cost savings I don't mind a little noise and it being a little heavier.
Our 2000 Honda will run the AC on low, and keep the fridge going. Depends on the unit.
But, bigger is better. Period. They don't work as hard and they'll usually use less fuel (big one at an idle as opposed to little one full out). And the bigger tanks, at lower R's means less refueling stops.
Well, after YEARS of wanting to get a small hand-portable generator I bought a new HONDA EE-2000 last summer
I had shoped pretty hard for one of these for quite some time and was more than a bit dissapointed in not being able to find a Killer Deal.
In the end the best price I could find was on E-Bay for a Brand New Unit was $885.00 And much to my surprise the local dealer in town was happy to meet that price. Shipping vs. Tax was a wash, so I went for the instant gratification and knowing I got a fully legit model with a 2 year factory warrenty.
For this particular purchase my main considerations were..
#1. Size, Weight, Portability.
The Honda EU2000 comes in VERY high on those requirements.
#2. Power output / Duration.
This thing goes and goes and goes on a gallon of gas, and can provide plenty of power for my intended uses.
#3. Cost.
I wanted something in the Sub $1,000 dollar range.
#4. Noise.
These little babies are VERY QUIET!
My intended use for this is as a "Camping" generator that I could pick up and take with us at a moments notice. And one that could be used to power the freezer in the garage or my HAM radios in a pinch.
My next generator will be a bigger unit.
I would like to get the EU-6500 as my #2.
I'd like to add a little more info to this Honda EU2000 concerning the parallel kit or the ability of hooking two of these generators together.
It is true that two EU2000 generators can be hooked together with a $50 pair of cables that will connect one generator to the other. However, if the power demand goes above 2200 watts we will quickly run into a problem, if both generators are the same EU2000i and only have a 20 amp AC receptacle on the front of the unit. At 20 amps you will get a max of only 2200 watts at a 110 volts so adding the second generator only gets you another 800 watts from what a single generator provides continuously.
To get around this Honda makes a different model called the "companion" EU2000 that has a 30 amp 220 style AC receptacle which allows you to get the max of 3200 watts combined from the two generators connected together. This unit though is a little more expensive and you have to know to order it separately from the regular model in order to get the 3200 watt benefit of hooking the two together. Even so, you are only getting 3200 watts and not the 4000 watts when hooked together because the EU2000 only provides 2000 watts surge and is rated at 1600 watts continuous use per individual generator.
There is one more solution in the form of an after market specialized parallel kit which provides the 220 style 30 amp receptacle in an external case or plug. These kits run from $100 to $200 dollars. You could make a similar "kit" by buying the parallel cables from Honda and then cutting and splicing in a 30A 220 volt style receptacle in between the two ends.
Here is a link to what the after market parallel kit looks like:
Spend the money on a honda or yamaha, I tried a chinese yamaha clone that didn't even make a weekend, now I have a honda eu3000i that works flawlessly.
Get a nice quiet dependable Honda EU. Do everyone a favor and leave the stinking loud a$$ed job site generator at the job site.
Linking the two EU2000's with the 30A plug set-up is the way to go IMO. You'll pay just a tad more than an EU3000 set-up, but you dont always have to lug both gennies with you and you will have higher continuous output.
I can run the AC on low in my Weekend Warrior with just one EU2000, but its running full blast to do it. Otherwise it just putters along nice and low to run the lights, converter, fridge...It will run around 16 hours on a tank with a light or two, converter, and fridge.
get the 5000 honda. if you got any load on a suitcase the fuel don't last long 2hrs max.
If you want a to get a yamaha that would power everything and parts of your house if need be, I work at Action Sports in Marshall MN and we sell Yamaha generators, I can set you up with a brand new 6600 watt yami for msrp is 2999, for only 1399 plus tax, bought a bunch on an auction so I can pass the savings on to you. Any questions shoot me and email and jake@yourwaytofun.com or call 507-532-9649 ask for Jake.
I have the Yamaha EF2400is. Very quiet (I used to leave it under the slide of my trailer), and ran the roof AC and fridge on my 2004 holiday trailer. Hitting the microwave while the AC ran would kick the breaker on the genny. Would run about 20 hours on 6l of fuel (1.5 gal). 1 man liftable (easy). I think I got it for around 1200 bucks Canadian. My pals Pecos and DRD have the Honda EU3000's. Also excellent gennys and quiet, but a bunch heavier to tote around by yourself. They were around 2100 bucks Canadian (I think).
http://www.yamaha-motor.com/outdoor/products/modelhome/475/0/home.aspxhttp://yamahagenerators.com/ef2400is_pr_4.html
I have the two Honda 2000i and tie them together for my camper and then use just one for my snowmobile trailer in the winter. they are the way to go. A little expensive, but quiet and worth it. Those cheap ones are just too load for me. They are a little cheaper on eBay from a place in Great Falls that is where me and all my buddies have got theirs.
Linking the two EU2000's with the 30A plug set-up is the way to go IMO. You'll pay just a tad more than an EU3000 set-up, but you dont always have to lug both gennies with you and you will have higher continuous output./QUOTE]
This is a great idea, as I have the 3000 and it is heavy. If I knew then what I know now, I would have went with two 2,000's, as I really don't run the air that much.
I think it really depends what air conditioning unit you have to what power generator will run it.Some air conditioners require alot more power for startup than others.
