Eric, I would have to agree with RON, at some point it is what it is..get it as close as possible and run it..if the belt temp and wear are good..clutching has to be pretty close under load........good info guys...
Interesting thread, it has me wondering how many miles and how hard these sleds have been ridden that you guys are finding like this? Has anyone taken these measurements on a new IQ? I'm wondering with the results Erics' finding, how much would they change with some new factory motor mounts? I can't help but wonder how much wear in the motor mounts (boost especially) could be contributing to this.
OK here is another intersting twist to my situaation. I borrowed the Polaris SPX "LWT" tool today from my deal and did some checking. The following numbers were achieved with the secondary pushed into the shaft, and the tool laying across the upper 1/3 of the secondary above the bolt (Upper) and with the tool laying across the lower 1/3 below the bolt (Lower). Two measurement were taken, at the front of the secondary and at the rear.
Polaris Tool - Upper Measurement
Front = .029"
Rear = .098" .069" difference
Polaris Tool - Lower Measurement
Front = .021"
Rear = .060" .039" difference
SLP Tool - Upper Measurement
Front = .230"
Rear = .374" .144" difference
SLP Lower Measurement
Front = 0 Just touched
Rear = 0 " " No difference
So what the hell does all this mean? It looks like my motor is not only rotated clockwise, but it is also lower on the PTO side, is this correct?
I dont know what to think.
This is what I mean by upper and lower
Upper
Lower
Thanks again for all the help. EW
In addition, setting up the center to center distance "dead-on" at 11.5" is also a mistake for the same reasons. Under load, the crankshaft gets closer to the jackshaft, so if you set up right on spec., center to center measurement gets further and further off the more load you put on the driveline. You want the clutches to work themselves closer to perfect alignment and center distance with increasing load, not move further away from it.
And then you would have to find out if the factory specification has already take all these variations into account? I mean, is the factory center-to-center distance given "in rest" and it is supposed to be shorter during load. I think it would be very impractical to give the measurements under load as how are you supposed to easily check/adjust the motor mounts while motor is under load and not lose a finger?
Obviously, you can't make the measurement with the motor under load (and don't ever attempt it!!), but that doesn't mean that the factory spec takes into account any of the things I mentioned previously. The factory spec is a "guideline" based on some theoretical "ideal situation". The factory doesn't sit down and figure out how much parts flex, how much belt lengths vary, how much the motor twists, etc. The spec is the same whether it's a fan cooled 440 or an 800 triple/triple. Common sense would say that those motors will move different amounts under load, flex other components differently under load, etc, right? If the spec took this into account, the spec should be unique for each motor in the lineup. Here is another one: If you've handled enough drive belts, you know how much they can vary in length. If the length doesn't match the "ideal", that center to center distance given in the factory spec is wrong for the belt - yet the factory spec doesn't make any allowance for that. Instead, they "fudge" it with an adjustable secondary clutch. A race team will sort their belts and find the ones that match most closely with their setup. That is the difference between "on paper", which is what the factory does and what is "real life", which is what a race team or a dedicated owner might look into. There are a lot of things in the sled that the factory does "on paper" and end up only being "close enough" to make your sled run and go down the trail.
On the bold, I checked the "mis-alignment " on my 2007 DRAGON 700 when it was brand new, 1 week old, after putting 500 miles on it.
.180" air gap @ the back of the secondary, had to slot the engine bracket nearly 3/8" to get it straight.
I've got one more D7 to check soon, will post results.
Diamonddave, my sled was out by the stated amounts prior to running the turbo. I first checked it after I pulled the motor during the turbo build but it had not run yet. Sled had about 800 stock miles. These numbers / gaps have not really increased in 600+ bosted miles. I will be checking several new sleds next week just to see how it shakes out.
Cool, I hope my question didn't ruffle feathers, just had me pondering the what if's as we've seen weak mounts before. Eric, for some reason I had thought all your sleds' miles were on boost. The only other thing that I'm wondering is are we dealing with a perfect in-line jackshaft? I know it doesn't matter which is actually out of alignment, but it would be kinda nice to know why you guys have gotten such extreme alignment issues.
I will order an SLP tool tomorrow. I've got a new zero mile 09, an 860 R&R, and a 685 to rebuild so in my best Chris Farley voice, "I'll check it out"
Cool info guys.
