R
RiotCountry
Ahh good to know!!The oil pump is electronic so you do not need any oil in the tank. Actually leans it out.
Do you by chance have a link to the washer? I am not as familiar with the team clutch, but do I need a special tool to swap springs or can I just unscrew the cover like the AC clutches and pop the new spring in?My Team roller primary seemed to eat a Dalton spring every 250 miles. Lots of digging/binding indicated in the cover without a washer. Added two of the Thunder products washers and went to a speedwerx spring. Seems to be better so far. The coated steel Thunder washers are pretty thin.
I just picked up a 2021 Riot X. Haven't looked into this much, is that the only tool for the job? Also, I assume cat clips are the only option?Yes don't add oil to your tank- and don't use a glide washer on the under side of your primary cap.. you changing the spring rate by doing so ( shorter) believe me it does.
I fully clip all the alpha's that come thru my shop, easy to do you will need 23 clips and I use this tool..
https://www.atwindustries.com/product/snowmobile-track-clip-tool-for-up-to-3-1-lug-paddle/
No special tools to swap springs. Just pull the cover like past clutches. Just be careful putting the cover back on... they are machined to very tight tolerances on the cover to tower connection (some say the cover groove diameter is actually a touch too small). So make sure it is seated all the way down before tightening the bolts up all the way.Do you by chance have a link to the washer? I am not as familiar with the team clutch, but do I need a special tool to swap springs or can I just unscrew the cover like the AC clutches and pop the new spring in?
You can order flat clips that have the grip range, but we prefer to have the OEM to guide the track.I just picked up a 2021 Riot X. Haven't looked into this much, is that the only tool for the job? Also, I assume cat clips are the only option?
Check those bearings.2019 M8000, 1100 miles...engine let go...specifically the clutch side piston/cylinder are smoked...they look oil starved to me......anyone have any cause for why this might happen or things to look at before it gets put back together? Any info and help is appreciated
