You would think.....But what do we know, we're just the suckers that buy them. Brought this up (sealed relays/connectors)with Polaris Reps but they just gave me lip service. On a part of the electrical system thats this important, until this happens, I won't be buying another Polaris.Better yet... fully sealed relays with sealed connectors and tin plated terminals. .
Need to do some thing with 2018 ?
Can one of the electrical guys say what is the difference of the Panasonic CM1-R vs. the CM1a-R ?I believe this one, with a resistor would be a better substitute....
http://www.mouser.com/search/ProductDetail.aspx?R=0virtualkey0virtualkeyCM1a-R-12V
https://www.mouser.com/Search/ProductDetail.aspx?qs=UO/x91QLkSAmnhevrmEMKQ==
Been watching this thread for a bit now. . . Finally pulled the trigger jumping ship from Cat to a 2017 rmk. . . I just did this tonight to help seal the relay base. Then I'm going to get them turned up with the bases down and tape around each relay. . . Mine were still factory taped and there's some dielectric grease in the pins for sure. Hope this dosent hold the moisture and make the problem worse.![]()
Sent from my SM-G920W8 using Tapatalk
FYI, dialectric grease IS silicone, or also known as silicone grease. It's basically a silicone that never hardens. It's also an insulator and does NOT conduct electricity in any way. Too many times, I've come across folks that put dialectric grease directly on plug pins/contacts, thinking that the grease somehow both helps protect from corrosion and helps conduct electricity. Keep it off the contacts.Silicone
MH, I completely concur with ya! When everything on the sled is electrically monitored or run, why in the HE(double Hockey sticks) would they choose to outsource the wiring harnesses to Honeywell's Chinese Division? It's like giving a Lamborgini or Ferrari a Krylon paint job. Sacrilege! Are Polaris engineers really a bunch of hillbilly rednecks or what? Or is that just the displaced mid-west Farmer mentality?
I would bet, if someone was so inclined they could make a quality harness and sell a mint of them. Use Fine strand copper wire with Arctic grade insulation (like Polar Wire makes and is well known for). Use quality connectors and components even if it requires the connectors be changed on the connecting components. Loom it properly (no electrical tape to hide their hideous workmanship).
By and Large the biggest "Issue" with the AXYS and was for the PRO Ride also.
