I installed it the other day and went for a ride and it worked good but today I went for a rip and u could hear it dumping air and the sled would only rev to 7400 rpm. But u could stop go again and I pulled 8050 rpm and everything was fine. Has anyone had this problem?[/QUOTE
Yep, same probem here; however, all I have to do is back out of the flipper real quick and then back into it and it's fine. Will do this on at least half of the climbs. Doesn't seem to do this down the trail though.
Been spending too much time with the damn clutch/belt problems, not to mention work, to worry about it. Maybe someone from EVO or ? can chime in with input.
Frick me. I wish when u buy some thing it would work. I will try it tomorrow thanks for the input
Something for people to look at (to avoid problems in the future) is to make sure the BRV is not touching anything. I ended up shortening both hoses to get the BRV away from the frame bracing. We have had several in for service and noticed most are hitting the brace after the hood is installed. Maybe this would cause magnified vibration and loosening of the cap.
Here is a picture showing how I have mine. Even if it were to be pushed down by the hood it clears the frame brace.
Interesting blanket over the muffler. Can you enlighten me and tell me if this comes with a certain muffler or did you buy something to put on there or? Take afew pics?
