I definately would like to address the issue we've began to see with a couple sets of our "Arctic Cat" brand specific reed petals.
I spent much time this past weekend with our machinist and engineer of our particular grade of spring steel to find the problem. I have seen the photos and tested further on the Cat petals we had in stock and the issue has occured only in a few of the Arctic Cat sets that were sold.
We couldn't figure out why our standard Polaris sized reeds and much larger Dragon/ CFI reeds have worked flawless with no failures reported back to us. Plus, as I've said before, we have been operating our Turbo Vmax-4 spring steel reeds since early fall and have been problem free with over 36 psi of boost on the same set.
When we laid all sets side by side to inspect, the problem we found was pretty clear. As Tewstroke reported, the "grain" structure of our Arctic Cat reeds flowed across the width of the petal instead of flowing from mounting base to petal tip. This creates a weakness on the tips and center of the Arctic Cat reeds as evident by his photos. The tips will pre-maturely wear away because of the grain flow direction is weaker.
I think its an issue that has affected a few customers now and yet we have customers with almost 1000 miles on the same set of our Arctic Cat reeds running up to 20 psi of boost. Regardless, the issue has been addressed now and appropriate actions taken to cure the issue. All future orders and current orders will receive their reeds with the new layout design.
To also clear any confusion for our Polaris and Yamaha customers, your reeds have the correct layout and strength, this was just an isolated problem with the "Arctic Cat" reeds only.
For those of you riders that purchased "Arctic Cat" reeds from Pro's Choice Power & Performance directly and were originally willing to test and give me feedback, you will be receiving a new complimentary set of our updated Arctic Cat reeds to prevent any possible issues even though they are still operating satisfactory.
I would like to close this by saying I apologize for any issues this may have caused and I'm very thankful no engine damage occured or was reported. It was an issue that just recently began to rear its ugly head and with many of our customers racking up lots of miles on the same set it was hard to determine the real problem, thankfully it was just something as simple, yet important as the layout.
Anybody with questions may contact me directly at 715-271-5487
Thank you,
Justin Durand
