T
Greetings,
Last night I discovered a ton of movement in my motor. Tore into it today and discovered both bolts that mount the motor mount bracket to the motor were broken on the right side of the motor. See the circled bolts in the below diagram.
I was able to use an easy out to back the broken studs out but have a few questions on the replacement bolts. Any help is appreciated.
1. It seems the bolt hole is much longer than the stock bolts. Is there any reason I can’t use a longer bolt?
2. I’m surprised a lock washer isn’t used. Any reason not to use one?
3. What are the thoughts on using locktite: either blue or red? It seemed the old bolts don’t have any.
4. A shop told my buddy the torque specs a let 50 ft pounds; is this correct?
Thank you for the help!
![799DB60A-F422-4FF6-8DCB-D3E4146CCC81.jpeg 799DB60A-F422-4FF6-8DCB-D3E4146CCC81.jpeg](https://www.snowest.com/forum/data/attachments/310/310039-1a716387ee3417a3adca24b6a84e3259.jpg)
![9251E5AE-A94B-4BC0-ACC5-0C84B8CDBB34.jpeg 9251E5AE-A94B-4BC0-ACC5-0C84B8CDBB34.jpeg](https://www.snowest.com/forum/data/attachments/310/310046-0750a20e2389afd26a6a3916316689b2.jpg)
![D689EED8-538C-4579-8DC8-B98B9FE72665.jpeg D689EED8-538C-4579-8DC8-B98B9FE72665.jpeg](https://www.snowest.com/forum/data/attachments/310/310045-7dc0e549e47660c2447b8588350a97ba.jpg)
