you boys are highjacking someones thread here, have some respect!!!!
Make sure you clean your clutches every 4 or 5 rides. Do not have slipping. I run the stock spring wound up to 110. I aslo run the Shockwave, make sure you have the update done on the shockwave.
me three![]()
Hey Sawyer
I posted an thread on here months ago and recieved a few good replys as I was blowing belts out of control. I have desintegrated and blown blown cords that were on the motor side also.
This is what I found worked and I recieved the advise from a few people on this site.
I have been running 15-18# in deep snow 2-3 feet coastal snow with great success.
Secondary: Cat Green @ 0-2 or 0-3 with shockwave @ 1 and 1.5 turns on shock wave. If pulling cord on motor side remove shim from the secondary.
Primary: 8bu fully loaded(aprox 58 grams)
Yes I would have never thought this set up would work but it does. I went from dalton 78grams to those 58's and it worked. Yes hard to believe.
However I do lots of tree riding and find if I'm in the deep and hard off and on the throttle I may pull a cord. I have now done 1000 miles on 2 belts. I'm very impressed with the yamaha for that kind of power.
Give it a shot , bet it will work!!!!
hey wood 2 key me into the trick on the shock wave i pretty handy with an allen wrench!
