N
NM
Good question.Im almost there. Just got to ask some more questions. Figured that it would be best to ask them here in case others have the same question.
So the Nytro you did the testing on, did it have a head shim? What about changes to cam timing? My biggest concern is that these modifications on my engine have changed the engines fueling requirements to the point where they are different enough that the factory ecu tune is not adequate. Maybe its so small of a difference for vacuum that it doesn't matter?
Thanks again.
My sled has 9.5:1 pistons and some cam work, as well as some port work.
I plumb the sleds so that the fuel regulator does not see vac at idle (just like stock). This way the fuel pressure is always consistant, and the low speed driveability is much smoother. The stock map at idle and low speed cruise can be adjusted in the factory ecu, and I have done this for the variance in turbo kit, cam timing, etc. For example, I set my CO's (factory idle and low speed cruise fueling) at plus 10, and the first Powderlite kit looks like it will have to be at about plus 25 or maybe more. This is a quick adjustment that can be done in a couple minutes at any time. Once it is set properly, then it should never have to be adjusted again. I will offer instructions how to do this, so anyone with my kit can make the adjustment. This setting is important for pre boost driveability and fuel economy. Once the sled is on boost, the fueling is very simple. Hope that helps.
